[postgis-users] Fatal: Symbol pj_set_searchpath
Christian Schaffer
christian.schaffer at muenchen.de
Tue Mar 4 01:17:33 PST 2008
Hi list,
compiling Postgis 1.3.2 on a Solaris 10 x86_64, I?m running into a fatal
error while executing lwpostgis.sql.
My prerequisites are:
Solaris 10, x86_64
Postgres 8.2.6 (packaged for Solaris by www.blastwave.org)
proj 4.4.8 (packaged for Solaris by www.blastwave.org)
geos 3.0.0 (compiled myself)
My configure options are:
./configure \
--with-proj=/opt/csw \
--prefix=/usr/local/postgis-1.3.2
The configure summary reads:
SUMMARY
HOST_OS: solaris2.10
PGSQL: /bin/pg_config
PROJ: prefix=/opt/csw libdir=/opt/csw/lib
ICONV: 1 -liconv
PORTNAME: solaris
PREFIX: /usr/local/postgis-1.3.2
EPREFIX: ${prefix}
DOC: ${prefix}/share/doc
DATA: ${datarootdir}
MAN: ${datarootdir}/man
BIN: ${exec_prefix}/bin
EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
I use gmake (gcc 3.4.5, packaged for Solaris by www.blastwave.org). No
errors during gmake and gmake install.
I then created a database (template_postgis) and issued
|createlang plpgsql template_postgis|
Importing lwpostgis.sql ends up with an error. I extracted the first few
lines of lwpostgis.sql into a test.txt:
CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
RETURNS histogram2d
AS '/usr/local/postgis-1.3.2/lib/liblwgeom', 'lwhistogram2d_in'
LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
This is the output:
# psql -d template_postgis -f test.txt -U postgres
psql:test.txt:4: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:test.txt:4: ERROR: could not load library
"/usr/local/postgis-1.3.2/lib/liblwgeom.so": ld.so.1: postgres: Schwerer
Fehler: Verschiebungsfehler: Datei
/usr/local/postgis-1.3.2/lib/liblwgeom.so: Symbol pj_set_searchpath:
referenziertes Symbol nicht gefunden
Google didn?t tell me much about this error. So I?d appreciate, if you
were able to help.
Thanks in advance, best regards,
Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080304/f109ddbf/attachment.html>
