[postgis-users] Fatal: Symbol pj_set_searchpath
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Mar 4 02:08:41 PST 2008
On Tuesday 04 March 2008 09:17:33 Christian Schaffer wrote:
> Hi list,
> compiling Postgis 1.3.2 on a Solaris 10 x86_64, I?m running into a fatal
> error while executing lwpostgis.sql.
> My prerequisites are:
> Solaris 10, x86_64
> Postgres 8.2.6 (packaged for Solaris by www.blastwave.org)
> proj 4.4.8 (packaged for Solaris by www.blastwave.org)
> geos 3.0.0 (compiled myself)
> My configure options are:
> ./configure \
> --with-proj=/opt/csw \
> --prefix=/usr/local/postgis-1.3.2
> The configure summary reads:
> SUMMARY
> HOST_OS: solaris2.10
> PGSQL: /bin/pg_config
> PROJ: prefix=/opt/csw libdir=/opt/csw/lib
> ICONV: 1 -liconv
> PORTNAME: solaris
> PREFIX: /usr/local/postgis-1.3.2
> EPREFIX: ${prefix}
> DOC: ${prefix}/share/doc
> DATA: ${datarootdir}
> MAN: ${datarootdir}/man
> BIN: ${exec_prefix}/bin
> EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
> I use gmake (gcc 3.4.5, packaged for Solaris by www.blastwave.org). No
> errors during gmake and gmake install.
> I then created a database (template_postgis) and issued
> |createlang plpgsql template_postgis|
> Importing lwpostgis.sql ends up with an error. I extracted the first few
> lines of lwpostgis.sql into a test.txt:
> CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> RETURNS histogram2d
> AS '/usr/local/postgis-1.3.2/lib/liblwgeom', 'lwhistogram2d_in'
> LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
> This is the output:
> # psql -d template_postgis -f test.txt -U postgres
> psql:test.txt:4: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:test.txt:4: ERROR: could not load library
> "/usr/local/postgis-1.3.2/lib/liblwgeom.so": ld.so.1: postgres: Schwerer
> Fehler: Verschiebungsfehler: Datei
> /usr/local/postgis-1.3.2/lib/liblwgeom.so: Symbol pj_set_searchpath:
> referenziertes Symbol nicht gefunden
> Google didn?t tell me much about this error. So I?d appreciate, if you
> were able to help.
> Thanks in advance, best regards,
> Chris
Hi Chris,
Ahhh ooops - looks like the pj_set_searchpath() call I added to help the Win32
builds find reprojection files is only present in PROJ 4.4.9 or above :(
The quick solution is to download and install the latest PROJ.4 version and
rebuild PostGIS - everything should then work as intended.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
