[postgis-users] Fatal: Symbol pj_set_searchpath
Tue Mar 4 05:34:41 PST 2008
Christian Schaffer wrote:
> Hi list,
> compiling Postgis 1.3.2 on a Solaris 10 x86_64, I?m running into a fatal
> error while executing lwpostgis.sql.
> My prerequisites are:
> Solaris 10, x86_64
> Postgres 8.2.6 (packaged for Solaris by www.blastwave.org)
> proj 4.4.8 (packaged for Solaris by www.blastwave.org)
> geos 3.0.0 (compiled myself)
> This is the output:
> # psql -d template_postgis -f test.txt -U postgres
> psql:test.txt:4: NOTICE:  type "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:test.txt:4: ERROR:  could not load library
> "/usr/local/postgis-1.3.2/lib/liblwgeom.so": ld.so.1: postgres: Schwerer
> Fehler: Verschiebungsfehler: Datei
> /usr/local/postgis-1.3.2/lib/liblwgeom.so: Symbol pj_set_searchpath:
> referenziertes Symbol nicht gefunden
> Google didn?t tell me much about this error. So I?d appreciate, if you
> were able to help.
Chris,
It appears that pj_searchpath() was added to PROJ.4 in 4.4.9 (back in 2004!)
I think you will need to either upgrade to a newer PROJ.4 or comment out this
call which may impede finding datum shift files.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
