[postgis-users] Problem with Z coordinate using postgis-jts
Fernando González fergonco at gmail.com
Thu Mar 6 01:31:39 PST 2008
After debugging a bit I have found that the postgis-jts code identifies
perfectly the dimension. I think the problem is in JTS. If anyone is
interested, I have made this test:
        CoordinateSequence cs = new PackedCoordinateSequence.Double(1, 2);
        cs.setOrdinate(0, 0, 10);
        cs.setOrdinate(0, 1, 10);
        Coordinate coord = cs.toCoordinateArray()[0];
        System.out.println(coord);
and it outputs:
(10.0, 10.0, 0.0)
instead of
(10.0, 10.0, NaN)
I'm moving to the JTS mailing list. Thanks for the help.
Fernando.
On Thu, Mar 6, 2008 at 10:17 AM, Fernando González <fergonco at gmail.com>
wrote:
> Thanks Kevin. I'm using your solution. However, there is another real
> difference: it takes twice the time to parse with that method. I have
> inserted this code to test:
>         String geom = rs.getString(2);
>         WKBReader reader = new WKBReader();
>         JtsBinaryParser parser = new JtsBinaryParser();
>         String bytes = rs.getString(2);
>         long t1 = System.currentTimeMillis();
>         for (int i = 0; i < 1000000; i++) {
>             Geometry g = parser.parse(bytes);
>         long t2 = System.currentTimeMillis();
>         System.out.println((t2 - t1) / 1000000.0);
>             Geometry g = reader.read(WKBReader.hexToBytes(geom));
> Is the postgis-jts stuff supported at all? My ignorance says it's not
> difficult to fix... I'm taking a look at the source to see if I can see
> something.
> Fernando.
> On Wed, Mar 5, 2008 at 10:22 PM, Kevin Neufeld <kneufeld at refractions.net>
> wrote:
> > Alternatively, don't use the postgis jar at all ... use a regular
> > postgres driver and JTS.  This yields the results you are looking for.
> > The only real difference here is the use of WKBReader instead of
> > JtsBinaryParser.
> >    public static void main(String[] args) throws Throwable {
> >        Class.forName("org.postgresql.Driver").newInstance();
> >        String sql = "CREATE TABLE test (pk_0 int4 NOT NULL);";
> >        sql += "select
> > AddGeometryColumn('test','the_geom','-1','GEOMETRY','2');";
> >        sql += "insert into test " + "values(3, "
> >                + "GeomFromText('LINESTRING(191232 243118,191108
> > 243242)',-1));";
> >        Connection c = DriverManager.getConnection(
> >             "jdbc:postgresql://turtle:9876/cwb/",
> >            "postgres",
> >            "postgres");
> >        Statement st = c.createStatement();
> >        try {
> >            st.execute("drop table test");
> >        } catch (SQLException e) {
> >        st.execute(sql);
> >        ResultSet rs = st.executeQuery("select * from test");
> >        rs.next();
> >        Coordinate[] coords = g.getCoordinates();
> >        for (int i = 0; i < coords.length; i++) {
> >            System.out.println(coords[i]);
> > -- output is
> > (191232.0, 243118.0, NaN)
> > (191108.0, 243242.0, NaN)
> > Kevin Neufeld
> > Software Developer
> > Refractions Research Inc.
> > 300-1207 Douglas St.
> > Victoria, B.C., V8W 2E7
> > Phone: (250) 383-3022
> > Email: kneufeld at refractions.net
> > Fernando González wrote:
> > > Thank you for the answer. When I execute this code:
> > >         sql += "select
> > >                 + "values(3, "
> > > 243242)',-1));";
> > .getConnection("jdbc:postgresql://127.0.0.1/gdms/test",
> > >                         "postgres", "postgres");
> > >         ((PGConnection) c)
> > >                 .addDataType("geometry", org.postgis.PGgeometry.class
> > >         ((PGConnection) c).addDataType("box3d",
> > > org.postgis.PGbox3d.class);
> > >         try {
> > >         st.execute(sql);
> > >         rs.next();
> > >         Geometry g = parser.parse(geom);
> > >         for (Coordinate coordinate : coords) {
> > >             System.out.println(coordinate);
> > > I obtain this output:
> > > (191232.0, 243118.0, 0.0)
> > > (191108.0, 243242.0, 0.0)
> > > I think I should obtain
> > > am I wrong?
> > > Fernando.
> > > On Wed, Mar 5, 2008 at 12:14 PM, Mark Cave-Ayland
> > > <mark.cave-ayland at siriusit.co.uk
> > > <mailto:mark.cave-ayland at siriusit.co.uk>> wrote:
> > >     On Wednesday 05 March 2008 10:13:26 Fernando González wrote:
> > >     > Hi,
> > >     > I'm storing and reading some geometries from a postgis table.
> > >     The table is
> > >     > 2D. I'm using a jar I have compiled with the "make postgis_jts"
> > >     command. It
> > >     > works very well except for one thing. I write 2D JTS geometries,
> > >     this is
> > >     > with the z component equal to NaN, into a postgis table but when
> > >     I read
> > >     > them the Z coordinate is no longer equal to NaN but equal to 0.
> > >     is this a
> > >     > feature? a bug?
> > >     > I'm using this code to read the geometry. To store them I use
> > >     GeomFromText
> > >     > function and I specify only X-Y components for each coordinate
> > >     (I'm not
> > >     > specifying the Z coordinate):
> > >     > String bytes = rs.getString(fieldId);
> > >     > Geometry geom = parser.parse(bytes);
> > >     > is it clear? I can write some code to reproduce the problem if
> > >     anyone is
> > >     > interested.
> > >     > Thanks in advance,
> > >     > Fernando
> > >     Hi Fernando,
> > >     Yes please. I may not be the person that eventually looks at this,
> > >     however a
> > >     reproducible test case is enormously helpful in cases like these.
> > >     ATB,
> > >     Mark.
> > >     Mark Cave-Ayland
> > >     Sirius Corporation - The Open Source Experts
> > >     http://www.siriusit.co.uk
> > >     T: +44 870 608 0063
> > >     _______________________________________________
> > >     postgis-users mailing list
> > >     postgis-users at postgis.refractions.net
> > >     <mailto:postgis-users at postgis.refractions.net>
> > >     http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080306/eb17ee04/attachment.html>
