[postgis-users] Fatal: Symbol pj_set_searchpath
Christian Schaffer
christian.schaffer at muenchen.de
Thu Mar 6 03:15:47 PST 2008
Mark Cave-Ayland schrieb:
> On Thursday 06 March 2008 09:42:29 Christian Schaffer wrote:
>> Hi list,
>> hello Mark and Frank,
>> thanks for your replies.
>> I backed out the precompiled proj 4.4.8, compiled the latest version of
>> proj (4.6.0) from scratch and adapted the LD_LIBRARY_PATH. After that, I
>> configured and compiled postgis anew with minimal options:
>> ./configure \
>> --with-pgsql=/opt/csw/postgresql/bin/pg_config \
>> --with-proj=/usr/local/proj-4.6.0 \
>> --prefix=/usr/local/postgis-1.3.2
>> Trying to import lwpostgis.sql now throws the following error:
>> # /opt/csw/postgresql/bin/psql -d template_postgis -f test.txt -U postgres
>> psql:test.txt:4: NOTICE: type "histogram2d" is not yet defined
>> DETAIL: Creating a shell type definition.
>> psql:test.txt:4: ERROR: could not load library
>> "/usr/local/postgis-1.3.2/lib/liblwgeom.so": ld.so.1: postgres: Schwerer
>> Fehler: libproj.so.0: Öffnen fehlgeschlagen: Datei oder Verzeichnis
>> nicht gefunden
>> If I issue ldd against liblwgeom.so, it knows where to find libproj.so.0:
>> # ldd liblwgeom.so
>> libproj.so.0 => /usr/local/proj-4.6.0/lib/libproj.so.0
>> libgcc_s.so.1 => /opt/csw/lib/libgcc_s.so.1
>> libm.so.2 => /lib/libm.so.2
>> libc.so.1 => /lib/libc.so.1
>> I?d really appreciate, if you gave me some hints on what I might be
>> doing wrong here.
>> Thanks in advance, best regards,
>> Chris
> Hi Chris,
> One thing to check is that you have set LD_LIBRARY_PATH for the user running
> PostgreSQL rather than your user, since it is the server process that
> attempts to load the shared library. So you need to stop the PostgreSQL
> server, add LD_LIBRARY_PATH to the environment for the postgres user, and
> then restart.
> HTH,
> Mark.
Hi Mark,
thanks for your reply.
I included the LD_LIBRARY_PATH to the postrgres user´s .profile, but bo
success yet. Do I have to set any of those parameters in postgresql.conf?
shared_preload_libraries = ''
#dynamic_library_path = '$libdir'
#local_preload_libraries = ''
Thanks once again an best regards,
Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080306/a077a089/attachment.html>
