[postgis-users] Fatal: Symbol pj_set_searchpath
Christian Schaffer christian.schaffer at muenchen.de
Thu Mar 6 06:48:16 PST 2008
Mark Cave-Ayland schrieb:
> On Thursday 06 March 2008 11:15:47 Christian Schaffer wrote:
>> Hi Mark,
>> thanks for your reply.
>> I included the LD_LIBRARY_PATH to the postrgres user´s .profile, but bo
>> success yet. Do I have to set any of those parameters in postgresql.conf?
>> shared_preload_libraries = ''
>> #dynamic_library_path = '$libdir'
>> #local_preload_libraries = ''
> Hi Chris,
> No, those parameters are fine as they are.
> I'm not sure that changes to the .profile will get placed into the environment
> if you launch a PostgreSQL instance from a script in /etc/init.d. You may
> need to tweak the init.d script to add a "LD_LIBRARY_PATH=foo" clause in the
> command line that launches pg_ctl.
> HTH,
> Mark.
Hi Mark,
I did place a "LD_LIBRARY_PATH=foo" and "export LD_LIBRARY_PATH" into
the /etc/init.d script already, but it didn´t work.
Your hint to put the clause in the command line that launches pg_ctl did
the job. Problem solved!
Thank you very much for helping.
Best regards,
Chris
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080306/e7f4ee53/attachment.html>
