[postgis-users] Raster suggestions?
Jeshua Lacock
jeshua at 3DTOPO.com
Sat Mar 8 19:39:45 PST 2008
On Mar 8, 2008, at 11:31 AM, guido.lemoine at jrc.it wrote:
> If your raster data is only for display purposes, it does not
> make sense to put them in a data base. You should look
> at an efficient raster access protocol. Google's SuperOverlay
> mechanism (image pyramids) is very interesting. Creation of
> SuperOverlay was recently implemented in GDAL.
> You can always keep the metadata in the database, to do
> fast searches on your coverage. SuperOverlays can be extended
> to handle local projection, if you need something else than longlat
> (which is usually the case).
Greetings Guido,
Yes - my products are UTM, however, I am not sure what projection the
online version will be as I don't want to have to deal with multiple
zones...
> If you somehow need programmatic access to your raster data (e.g.
> extracts, image processing) you need to develop some geo-spatial
> application server layer, which would combine your PostGIS feature
> data with the rasters in the SuperOverlay structures.
Thanks for the information about SuperOverlay - sounds perfect - I
will check it out now.
> What puzzles me is the combination of 10 TB of data and a shoestring
> budget. This requires some nasty server solution, whatever the
> mechanism you want to use. It's the playing ground of the Google,
> Virtual Earths, NASA WorldWind kind of folks.
> Not really the shoestring kind.
Yes - I understand your point. I am self-funded (been working on my
solution for 10 years now). I am starting out with about 50 GB of
imagery and working my way up (each quad is about 120 MB in imagery +
pyramids). I am past my initial startup phase (I have product in
stores) and the more products I have the better my budget will be.
Also, now that I have product in stores, I am looking at putting it
online which will be done one quad at a time (I plan to have a free
viewer and sell higher resolution [with vector art] downloadable
PDFs). I have two types of products planned - a provisional
autonomously created product and a manually updated current product.
I am getting close to letting my system "rip" on entire states for the
provisional version. As I add more and more products online and in
stores, I should have more and more capital to invest.
In other words, I am not just going to start out with 10 TB - that is
sometime down the road. And thanks to Moore's law - storage and more
powerful servers will be much more affordable by the time I have 10 TB
to serve.
Ciao,
Jeshua Lacock
Founder/Programmer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 877.240.1364
