[postgis-users] Does geometry field type have a size limit?
davidj2k davidj2k at yahoo.com
Wed Mar 12 11:06:14 PDT 2008
That was it, the value was actually there but when I looked at it in pgAdmin
III it just did not draw the text.  Thank you very much.
davidj2k wrote:
> I am trying to convert several of my .shp files to the PostGIS database
> and when it inserts some of the larger polygons it fails to insert the
> geometry field value.
> I tried it using the shp2pgsql and I tried it using my own code in C# and
> I have even tried executing the SQL in the pgAdmin III Query function and
> all three have the exact same results the record gets inserted but the
> geometry field is null and it only happens on those records that have a
> lot of points that make up the polygon, I created several test to try and
> determine how many points were too much for it and I hit upon 1365 seemed
> to be the amount that was too many.
> Does anybody know if there is a limitation to the geometry field and if
> there is how can I increase it?
> Thank You
View this message in context: http://www.nabble.com/Does-geometry-field-type-have-a-size-limit--tp16006438p16011005.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
