[postgis-users] Topological Exceptions
Kevin Neufeld
kneufeld at refractions.net
Wed Mar 12 16:27:37 PDT 2008
Martin Davis wrote:
> A reasonable concern.
> To which some might be tempted to reply RTFM. (I think this is the
> solution offered by some proprietary vendors...)
> Would having parallel sets of functions, (Paranoid/Laissez-faire) be
> an option? Unpleasant to widen the API, however.
We could override the methods to take an addition parameter,
'ignore_exceptions boolean'.
In which case, we would have:
ST_Contains(geom,geom,boolean) => true, false, or null (if set to true)
ST_Contains(geom,geom)
a simple wrapper for ST_Contains(geom,geom,false)
This way, people's queries won't break or wonder why the change in their
outcomes. If they want the "null" behaviour, they can ask for it.
-- Kevin
>> On 3/12/08, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> This means that the return values of
>>> ST_Contains(geom,geom) => true, false or null
>>> and
>>> ST_Intersection(geom,geom) => geometry or null
>>> I just checked, and null seems to be interpreted as false in a WHERE
>>> clause, so adding this behavior probably wouldn't wreck too many
>>> joins.
>>> Paul
