[postgis-users] Topological Exceptions
Paul Ramsey
pramsey at cleverelephant.ca
Wed Mar 12 16:44:46 PDT 2008
Since the current behavior results in queries which just don't run to
completion, I don't think that making the null behavior the default
would cause any harm. I am concerned that people notice that their
queries are in fact skipping some of the geometry pairs due to the
exception swallowing.
P
On 3/12/08, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Martin Davis wrote:
> > A reasonable concern.
> > To which some might be tempted to reply RTFM. (I think this is the
> > solution offered by some proprietary vendors...)
> > Would having parallel sets of functions, (Paranoid/Laissez-faire) be
> > an option? Unpleasant to widen the API, however.
> We could override the methods to take an addition parameter,
> 'ignore_exceptions boolean'.
> In which case, we would have:
> ST_Contains(geom,geom,boolean) => true, false, or null (if set to true)
> ST_Contains(geom,geom)
> a simple wrapper for ST_Contains(geom,geom,false)
> This way, people's queries won't break or wonder why the change in their
> outcomes. If they want the "null" behaviour, they can ask for it.
> -- Kevin
> >> On 3/12/08, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> >>> This means that the return values of
> >>> ST_Contains(geom,geom) => true, false or null
> >>> and
> >>> ST_Intersection(geom,geom) => geometry or null
> >>> I just checked, and null seems to be interpreted as false in a WHERE
> >>> clause, so adding this behavior probably wouldn't wreck too many
> >>> joins.
> >>> Paul
> postgis-users mailing list
