[postgis-users] could not access file "$libdir/liblwgeom"
    Ryan Hodgson
    enoop at hotmail.com
    Thu Mar 13 10:36:29 PDT 2008
I am getting 'ERROR: could not access file "$libdir/liblwgeom": No such file or directory' when I am tring to load lwpostgis.sql.
>From the config.log
configure:6726: result:  SUMMARYconfigure:6728: result:  -------------------------------------------------------configure:6730: result:  configure:6732: result:  HOST_OS: linux-gnuconfigure:6734: result:  configure:6736: result:    PGSQL: /usr/local/pgsql/bin/pg_configconfigure:6746: result:     GEOS: /usr/local/bin/geos-config (with C-API)configure:6748: result:           (ldflags: -L/usr/local/lib)configure:6758: result:    ICONV: 1 configure:6761: result:   configure:6763: result:  PORTNAME: linuxconfigure:6765: result:    PREFIX: /usr/local/pgsqlconfigure:6767: result:   EPREFIX: ${prefix}configure:6769: result:       DOC: /usr/local/pgsql/doc/contribconfigure:6771: result:      DATA: ${datarootdir}configure:6773: result:       MAN: ${datarootdir}/manconfigure:6775: result:       BIN: /usr/local/pgsql/binconfigure:6781: result:       EXT: /usr/local/pgsql/lib (\$$libdir)
The file liblwgeom isn't in the /usr/local/pgsql/lib dir.  However there is liblwgeom.so, liblwgeom.so.1, liblwgeom.so.1.3.  Anythoughts?  Bad Make?
extra info... I had an exsiting pg install from yum.  I download pg source and compiled.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080313/15cda4f5/attachment.html>
