[postgis-users] NEED Win 64bit OleDb or ODBC Driver
Obe, Regina
robe.dnd at cityofboston.gov
Fri Mar 14 05:19:07 PDT 2008
I didn't read your last part about the linked servers deal. I was
planning to do the same thing for a SQL Server 2005 64-bit server and
went as far as installing the 64-bit driver I mentioned here
http://www.geocities.jp/inocchichichi/psqlodbc/index.html
Then I ran into another snaffu - (a Microsoft one) - evidentally or at
least last I checked, Microsoft has not released a 64-bit version of the
OLEDB Provider for ODBC needed to make 64-bit ODBC connections via
Linked Server
I think its called MSDAOSP or something of that sort which I think was
called MSDASQL in prior versions.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2495186&SiteID=
17
Let me know if you find out otherwise since I would be VERY INTERESTED
too.
I was thining of trying the OLEDB PostgreSQL driver, but not sure if
there is a 64-bit version of that and I think its a lot less tested
than ODBC.
I was hoping I could use the ADO.NET driver but haven't quite figured
out how to register that in the Linked servers providers list or if I am
missing yet another piece of glue.
Sorry couldn't be more helpful,
Regina
<http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2495186&SiteID
=17>
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sufficool, Stanley
Sent: Thursday, March 13, 2008 8:03 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] NEED Win 64bit OleDb or ODBC Driver
I am attempting to use linked servers (MSSQL / PG) on a 64bit platform.
I have been searching for a 64bit driver installer, but have yet to find
one.
Anyone have luck with this or do I need to roll my own?
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080314/d4169ddb/attachment.html>
