[postgis-users] shortest_path_dijkstra1_as_geometry_internal_id error msg
Edel Banks
osgisfyp at gmail.com
Tue Mar 18 16:12:16 PDT 2008
Hi All,
I just started using pgrouting. I followed the tutorial with my own data and
have everything setup but when I run:
SELECT astext(required_roads.the_geom), required_roads.name FROM
shortest_path_dijkstra1_as_geometry_internal_id (
'required_roads',18583::integer, 18597::integer, 300::double
precision)
AS T1 INNER JOIN required_roads on required_roads.gid=T1.gid;
I get this error message:
ERROR: operator does not exist: text || boolean
SQL state: 42883
Hint: No operator matches the given name and argument type(s). You may need
to add explicit type casts.
Context: PL/pgSQL function
"shortest_path_dijkstra1_as_geometry_internal_id_directed" line 100 at
assignment
PL/pgSQL function "shortest_path_dijkstra1_as_geometry_internal_id" line 15
at for over execute statement
As shown in the code above I added in explicit type casts but still no joy.
Can anyone tell me what the problem is?
Thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080318/c4eecc67/attachment.html>
