[postgis-users] Didn't install Proj4 and I need it. Clean install?
Colin Wetherbee cww at denterprises.org
Fri Mar 21 12:06:46 PDT 2008
R H wrote:
> I realized I should have installed Proj4.  Do I need to do any
> steps to remove PostGis and Geos to do a clean install with Proj4?
> This would be on a linux box.  thanks
If you've compiled PostGIS from source, I believe you need to
recompile it --with-proj and reinstall it after installing PROJ4.
Colin
