[postgis-users] ST_Union and 8.3?
Obe, Regina
robe.dnd at cityofboston.gov
Wed Mar 19 07:00:44 PDT 2008
This is a known issue which I think Mark Cave-Ayland is working on.
I think Mike Leahy had suggested using
ST_MemUnion as a work around.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
William Temperley
Sent: Wednesday, March 19, 2008 9:42 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ST_Union and 8.3?
Hello all
I'm having problems with ST_Union.
I get the error:
ERROR: Operation on mixed SRID geometries
SQL state: XX000
With the queries:
select st_union(the_geom) from tiles
select st_union(st_transform(the_geom, 4326)) from tiles
The second query cannot possibly have mixed srids!
st_collect works fine.
I've tried isvalid() and all is valid.
This works on the production server fine.
My version:
"1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
"PostgreSQL 8.3.0, compiled by Visual C++ build 1400"
Example inserts below:
insert into tiles values('2016~1326',
SetSRID(st_makebox2d(st_makepoint(-2.8125,53.38332836757156),st_makepoin
t(-2.724609375,
53.4357192066942)), 4326));insert into tiles values('2016~1327',
SetSRID(st_makebox2d(st_makepoint(-2.8125,53.33087298301704),st_makepoin
t(-2.724609375,
53.38332836757156)), 4326))
Any ideas what's wrong here?
Cheers
Will
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
