[postgis-users] Do I need to copy postGIS objects to my new schema?
kreshna_iceheart at yahoo.com kreshna_iceheart at yahoo.com
Tue Mar 25 20:26:21 PDT 2008
Thank you, Nicolas. When I make changes to the search path, it will stay permanent, won't it?
  Regards,
  -Kresh
Nicolas Ribot <nicky666 at gmail.com> wrote:
  > I'm planning to use database schemas to organize my spatial tables. For
> example, all spatial tables of GIS objects belong to Bali island is to be
> kept in a schema named "bali", etcetera.
> Problem is, when I created a new schema named bali, it did not inherit all
> the postGIS objects of the public schema.
> As you can see on the attached screenshot (I'm using pgAdmin III), the
> public schema contains all the Aggregates, Domains, Functions, etcetera,
> which are all part of postGIS functionality. Examples are geomunion function
> and earth domain, which exist in the public schema but do not exist on bali
> schema.
> Can I use bali schema to store postGIS tables then? Or should I copy all the
> postGIS Aggregates, Domains, Functions, etc, to the bali schema in order to
> make it work? And if that's the case, anyone know the easiest way to do so?
Postgis functions should stay in the public schema. No need to copy them.
You will be able to use them on the bali.* tables by either fully
qualifying the tables' name in your queries or by adding your newly
created schema to the search path (no need to qualify tables names
with the schema in this case)
Nicolas
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________________________________________________________________
So be it. If saying "NO" means being alone, then to hell with love, with women, with marriage, with God, religions, bars, nightclubs, computer games, and all the shit life keeps pumping at me. I'll walk alone, but with freedom and a healed pride.
Looking for last minute shopping deals?  Find them fast with Yahoo! Search.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080325/4fc1e353/attachment.html>
