[postgis-users] Do I need to copy postGIS objects to my new schema?
Kevin Neufeld kneufeld at refractions.net
Tue Mar 25 21:22:25 PDT 2008
I think there three ways to change your search path.
-- Will temporarily set the search path for this connection only
SET search_path TO schema1, pubic;
-- Will set the search path for the specified user for all subsequent
connection (not the current connection)
ALTER USER username SET search_path to schema1, public;
-- change the postgresql.conf file to set the search path for all users
for all subsequent connections
search_path = '"$user", schema1, public'
Cheers,
Kevin
kreshna_iceheart at yahoo.com wrote:
> Thank you, Nicolas. When I make changes to the search path, it will
> stay permanent, won't it?
> Regards,
> -Kresh
> */Nicolas Ribot <nicky666 at gmail.com>/* wrote:
>     > I'm planning to use database schemas to organize my spatial
>     tables. For
>     > example, all spatial tables of GIS objects belong to Bali island
>     is to be
>     > kept in a schema named "bali", etcetera.
>     > Problem is, when I created a new schema named bali, it did not
>     inherit all
>     > the postGIS objects of the public schema.
>     > As you can see on the attached screenshot (I'm using pgAdmin
>     III), the
>     > public schema contains all the Aggregates, Domains, Functions,
>     etcetera,
>     > which are all part of postGIS functionality. Examples are
>     geomunion function
>     > and earth domain, which exist in the public schema but do not
>     exist on bali
>     > schema.
>     > Can I use bali schema to store postGIS tables then? Or should I
>     copy all the
>     > postGIS Aggregates, Domains, Functions, etc, to the bali schema
>     in order to
>     > make it work? And if that's the case, anyone know the easiest
>     way to do so?
>     Postgis functions should stay in the public schema. No need to
>     copy them.
>     You will be able to use them on the bali.* tables by either fully
>     qualifying the tables' name in your queries or by adding your newly
>     created schema to the search path (no need to qualify tables names
>     with the schema in this case)
>     Nicolas
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
> __________________________________________________________________
> So be it. If saying "NO" means being alone, then to hell with love,
> with women, with marriage, with God, religions, bars, nightclubs,
> computer games, and all the shit life keeps pumping at me. I'll walk
> alone, but with freedom and a healed pride.
> Looking for last minute shopping deals? Find them fast with Yahoo!
> Search.
> <http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping>
