[postgis-users] Get more polygon's exterior boundary
Obe, Regina
robe.dnd at cityofboston.gov
Fri Mar 28 06:13:16 PDT 2008
Probably because its been more or less deprecated.
For newer versions of PostGIS use ST_Union instead of geomunion.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kis János Tamás
Sent: Friday, March 28, 2008 4:51 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Get more polygon's exterior boundary
csütörtök 27 március 2008 14.51 dátummal "Nicolas Ribot"
<nicky666 at gmail.com> ezt írta:
> (yours is not a valid polygon because of the (10,20) last
> coordinates pair in the first ring, if you wanted to express the
> union of all polygons).
It was a keyboard misstake... ;)
> select st_astext(geomunion(the_geom)) from try;
Thanks!
...and why I didn't see the "geomunion" function in the documentation?
Regards,
kjt
McAfee SCM 4.1 által ellenrizve!
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
