[postgis-users] PostGIS install on postgres 8.3 running on 64bit OpenSuse10.3
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri May 2 07:00:11 PDT 2008
Calum Byrom wrote:
> Hi Mark,
> Thanks for the quick response.  I've tried what you suggested but to no
> avail.  Observations whilst doing this:
> i) If I install PostGIS from the unzipped source, via a ./configure,
> gmake, sudo gmake install, the lwpostgis.sql, etc scripts get put in
> /usr/share and contain unexpanded $libdir variables.  The liblwgeom
> files end up under /usr/lib64/postgresql
> ii) If I install PostGIS via the rpm, using the YaST2 GUI, the
> lwpostgis.sql, etc scripts get put in /usr/share/postgis and the $libdir
> variable they use is expanded to /usr/lib64 (although I don't think any
> expansion is actually being done since the timestamp on these files is
> quite old - so they're just being unpacked to this dir).  The liblwgeom
> files here get unpacked this libdir - i.e. /usr/lib64
> I've not done anything out of standard for any of the installs except
> for configuring the postgres install using, LDFLAGS=-lstdc++
> ./configure  - as suggested in the setup guide I was following (see link
> in first mail).
> Any other suggestions?
> Thanks,
> Calum.
Hi Calum,
What does the output of "pg_config" show? You should run this as the
same user you ran configure. You may also try "which pg_config" to see
from where configure is finding your PostgreSQL configuration information.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
