[postgis-users] question on returning area size using st_area.
Stephen Lee
stephenljk at gmail.com
Mon May 5 11:26:40 PDT 2008
hi there,
i've just started using postgis, i have loaded a sample map of malaysia
using the following command:
F:\PROGRA~1\PostgreSQL\8.3\bin>shp2pgsql -c -s 4326
G:\Maps\Malaysia\Detailsmaps\state_region public.mal_state > state.sql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
the projection file in the prj is as follow so I assume the SRID is 4326 :
GEOGCS["Lat Long
WGS84",DATUM["D_WGS84",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
the map is successfully loaded and can be viewed using uDig. The problem
occurs when I tried to use the st_area command as state in the PostGIS
(1.3.3) manual (4.6.2.2). the sql statement i issue is:
SELECT
ST_Area(the_geom)/10000 AS hectares
FROM mal_state
WHERE name = 'KELANTAN';
hectares
0.000122167591783352
(1 row)
is the return result measure in the unit of the WGS84 projection? if so how
can i change it to the correct measurement? i have attached my map file in
this email, can someone please shine some light? thanks in advance.
best regards,
Stephen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080506/59a21b27/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080506/59a21b27/attachment.zip>
