[postgis-users] Union of 2 polygon shape files
RAVI KUMAR
ravivundavalli at yahoo.com
Tue May 6 04:30:02 PDT 2008
Hi Havard,
what are equal opperation of Overlay in Post GIS.
Ravi Kumar
Havard Tveite <havard.tveite at umb.no> wrote: Dear Ravi,
You should specify what you expect the Union operation
to do.
The PostGIS (ST_)Union is not the same as an overlay (if
that is what you want to achieve).
The union operation joins two geometries or a set of
geometries (the aggregation version) together to form a
new geometry.
Håvard
ST_Union(geometry, geometry)
Returns a geometry that represents the point set union of the
Geometries.
Performed by the GEOS module
Do not call with a GeometryCollection as an argument
NOTE: this is renamed from "union" because union is an SQL reserved
word
OGC SPEC s2.1.1.3
ST_Union(geometry set)
Returns a geometry that represents the point set union of this all
Geometries in given set.
Do not call with a GeometryCollection in the argument set
Not explicitly defined in OGC SPEC
RAVI KUMAR wrote:
> Hi,
> I find that Union of 2 polygon shape files is not what is expected from
> other FOSS GIS like GRASS etc. I can send two small shape files with a
> few polygons and the anticipated result. Pl let me know to whom I should
> mail it for help, such that UNION with PostGIS can be used after
> necessary modifications.
> This will clear a roadblock for me in a exercise on Mineral
> prognastication using FOSS GIS.
> Ravi Kumar
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try
> it now.
Håvard Tveite
Department of Mathematical Sciences and Technology
Norwegian University of Life Sciences
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080506/6139d7fb/attachment.html>
