[postgis-users] Points with in multiple Polygons
chris brisendine
ki4gyw at gmail.com
Tue May 6 08:35:26 PDT 2008
Great Idea on the tornado intersect it does from time to time! It
worked great ! thanks, maybe one day it can save a life, If i wanted
to run the query from the command line would i use the psql -c
run.psql to output a list to a txt file? im getting a error with that
ERROR: syntax error at or near "run" at character 1
LINE 1: run.psql
Thanks alot your time is very appreciated!
