[postgis-users] Hibernate Spatial Postgis 3D
Max postgis at lists.meisel.cn
Wed May 7 08:04:07 PDT 2008
Hello,
first i want to thank Karel for the great hibernate-spatial extension.
Using this extension saves a lot of time.
These days i got the new sources from the svn, because i saw that Karel
was implementing the 3D stuff for the postgis-provider. So far so good.
After compiling and using the new provider i found out, that it doesnt
work for me, so maybe someone can help me to solve the problem. Writing
a 3D point to the postgis-db still returns a 2D point, so i dont know
whats wrong.
My files are looking like this (parts - taken from hibernate spatial
example)):
...hmb.xml
        <property name="theGeom" type="org.hibernatespatial.GeometryUserType">
            <column name="the_geom" />
        </property>
Class File
import com.vividsolutions.jts.geom.Point;
	public class Grd
	private Point	theGeom;
	public Point getTheGeom() {
		return this.theGeom;
	public void setTheGeom(Point theGeom) {
		this.theGeom = theGeom;
hibernateTest.java
		hibernateTest hbTest = new hibernateTest();
		hbTest.createAndStoreEvent("POINT(12 14 15)");
		HibernateUtil.getSessionFactory().close();
	private void createAndStoreEvent(String wktPoint) {
		// First interpret the WKT string to a point
		WKTReader fromText = new WKTReader();
		Geometry geom = null;
		try {
			geom = fromText.read(wktPoint);
		catch (ParseException e) {
			throw new RuntimeException("Not a WKT string:" + wktPoint);
		if (!geom.getGeometryType().equals("Point")) {
			throw new RuntimeException("Geometry must be a point. Got a " + geom.getGeometryType());
		Session session = HibernateUtil.getSessionFactory().getCurrentSession();
		session.beginTransaction();
		Grd theGrd = new Grd();
		Point p = (Point) geom;
	// at this point there is an Z-Coordinate ///
		System.out.println(p.getCoordinate().z);
		theGrd.setTheGeom(p);
		session.save(theGrd);
		session.getTransaction().commit();
After reading the Point from the DB using:
	private List<Grd> findAll() {
		Session session =
		Criteria testCriteria = session.createCriteria(Dgm050Grd.class);
		List<Dgm050Grd> results = testCriteria.list();
		return results;
// the Point has not Z-Coordinate, its just NaN
So whats wrong? I know to appreciate your hekp
best regards
Steffen
