[postgis-users] Importing shapefiles with srid != -1 [SOLVED]
James Dominy
james at sun.ac.za
Fri May 9 06:50:06 PDT 2008
Obe, Regina wrote:
> James,
> If you do a combined create table (and append) do you get the same error
> - might also help to create an intermediate file so
> you can inspect it for strange stuff. - e.g.
> shp2pgsql -s 4326 -g gisdata provinces.shp prov2 > prov2.sql
> psql psql -h myserver -d mydb -U myuser -f prov2.sql
> What OS are you running?
> Which version of shp2pgsql (which you can see at the top of the screen
> by calling shp2pgsql without args),
> postgis version? which you get by doing a SELECT
> postgis_full_version();
> Hope that helps,
> Regina
Ahh, thanks for the suggestions. It was an error in my PHP code, long and
convoluted to explain. But once I got the PHP code actually producing the
correct SRID in the modified insertion statements, it all came together.
Clearly, quotes make a difference ;)
Cheers,
James
