[postgis-users] Importing shapefiles with srid != -1
Stephen Lee
stephenljk at gmail.com
Fri May 9 09:21:54 PDT 2008
Hi James,
Why not try qGIS and use its import wizard to give it a shot?
regards,
stephen
On Fri, May 9, 2008 at 8:01 PM, James Dominy <james at sun.ac.za> wrote:
> Hi all,
> I have a shape file with an associated prj. The prj file says the shape
> file is in WGS84, so I'm using
> shp2pgsql -a -g gisdata -s 4326 provinces.shp GISProvices
> When I run the result through psql, I get
> ERROR: new row for relation "gisprovices" violates check constraint
> "enforce_srid_gisdata"
> The table definition is as follows...
> CREATE TABLE GISProvinces (
> region_id SERIAL PRIMARY KEY,
> name VARCHAR(255) NULL,
> layer INTEGER NOT NULL REFERENCES TGISLayer
> SELECT AddGeometryColumn('', 'gisprovinces', 'gisdata', 4326,
> 'MULTIPOLYGON', 2);
> Everything works fine if I don't specify any srid. As soon as I specify an
> SRID for either the column or the inserts (via -s with shp2pgsql), or both,
> even if they are the same, I get the error. What am I doing wrong?
> Thanks,
> James
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080510/ad02bcd1/attachment.html>
