[postgis-users] Polygon Combinations
Bryan K R Manuel
manue9fe at erau.edu
Thu May 15 12:21:40 PDT 2008
Hello,
I have a table of parcels and a table of trees, and I need to determine the parts of each parcel that are covered in trees and the parts that are not covered in trees. The following code seems to work, but takes forever to run (40 hours).
create table ttemp (
id int4,
usage char(1),
the_geom geometry
) without oids;
insert into ttemp (id, usage, the_geom)
select c.gid, 'A',
difference(c.the_geom,
( select geomunion(b.the_geom) from parcels a, trees b
where a.the_geom && b.the_geom
and overlaps(a.the_geom, b.the_geom)
and a.gid=c.gid
from parcels c group by the_geom, gid;
--Time: ~20hr
select c.gid, 'W',
intersection( c.the_geom,
and a.gid=c.gid
--Time: ~20hr
I thought that instead of having the inner join within the difference/intersection parts, it would be faster to make a separate table first, except what I've done so far is still taking a long time to run:
create table tptemp (
id int4,
the_geom geometry
) without oids;
insert into tptemp (id, the_geom)
select a.gid,
(select geomunion(b.the_geom) from parcels a, trees b
from parcels a group by gid;
select c.gid, 'A',
( select b.the_geom from tptemp b
where c.gid=b.id
select c.gid, 'W',
where c.gid=b.id
I am relatively new to PostGIS and PostgreSQL, so if anyone can help try to improve the performance of this code it would be greatly appreciated!
Thanks
