[postgis-users] Polygon Combinations
Andy Anderson aanderson at amherst.edu
Thu May 15 14:18:47 PDT 2008
I could be misunderstanding your intent or your SQL, but in your
inner select/where clause, I wonder about the order of your tests.
Shouldn't you make sure that a.gid=c.gid first, and then do the other
tests? Otherwise it appears that for every parcel, you're checking
every parcel against every tree polygon, i.e. N * (N * M) calculations.
You might want to look at this section of the Postgres manual where
it discusses how to force the order of evaluation:
	http://www.postgresql.org/docs/8.3/interactive/sql-
expressions.html#SYNTAX-EXPRESS-EVAL
-- Andy
On May 15, 2008, at 3:21 PM, Bryan K R Manuel wrote:
> Hello,
> I have a table of parcels and a table of trees, and I need to
> determine the parts of each parcel that are covered in trees and
> the parts that are not covered in trees.  The following code seems
> to work, but takes forever to run (40 hours).
> create table ttemp (
> id int4,
> usage char(1),
> the_geom geometry
> ) without oids;
> insert into ttemp (id, usage, the_geom)
>   select c.gid, 'A',
>     difference(c.the_geom,
>       ( select geomunion(b.the_geom) from parcels a, trees b
>          where a.the_geom && b.the_geom
>            and overlaps(a.the_geom, b.the_geom)
>            and a.gid=c.gid
>   from parcels c group by the_geom, gid;
> --Time: ~20hr
>   select c.gid, 'W',
>     intersection( c.the_geom,
>             and a.gid=c.gid
> --Time: ~20hr
> I thought that instead of having the inner join within the
> difference/intersection parts, it would be faster to make a
> separate table first, except what I've done so far is still taking
> a long time to run:
> create table tptemp (
> id int4,
> the_geom geometry
> ) without oids;
> insert into tptemp (id, the_geom)
>   select a.gid,
>     (select geomunion(b.the_geom) from parcels a, trees b
>   from parcels a group by gid;
>   select c.gid, 'A',
>       ( select b.the_geom from tptemp b
>          where c.gid=b.id
>   select c.gid, 'W',
>          where c.gid=b.id
> I am relatively new to PostGIS and PostgreSQL, so if anyone can
> help try to improve the performance of this code it would be
> greatly appreciated!
> Thanks
> postgis-users mailing list
