[postgis-users] couldn't get the correct projected values
orkun temiz at deprem.gov.tr
Fri May 16 01:00:03 PDT 2008
hello
whatever I have done, I couldn't get the correct projected values in
postgis environment.
1. # lon/lat to utm projection
create table izmir_il4 as select
gid,il_kod,iladi,transform(the_geom,32635) as the_geom from il_izmir3;
2.
update izmir_il4 set the_geom=setsrid(the_geom,32635);
3.
select extent(the_geom) from izmir_il4;
extent
BOX(26.2226982116699 37.8668251037598,28.4587249755859 39.3925666809082)
but these are not utm values. They are still in lon/lat values
I checked extent values with proj values. I got correct values:
echo "26.2226982116699 37.8668251037598" | proj +proj=utm +zone=35
+ellps=WGS84 +datum=WGS84
431631.23       4191323.84
orkun at orkun-desktop:/usr/local/izmir/veri/izmir3$ echo "28.4587249755859
39.3925666809082" | proj +proj=utm +zone=35 +ellps=WGS84 +datum=WGS84
625615.27       4361356.53
how can get values generated from "proj" in postgis environment ?
what am I doing wrong ?
here is the srid values of 32635 :
32635 | +proj=utm +zone=35 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
regards
Ahmet Temiz
Jeo. Müh.
Afet İşleri Gen. Md.lüğü
Deprem Ar. D.
Ahmet Temiz
Geo. Eng.
General Dir. of
Disaster Affairs
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
