[postgis-users] couldn't get the correct projected values
Paragon Corporation
lr at pcorp.us
Fri May 16 03:17:44 PDT 2008
You are confusing setsrid with transform.
Remember setsrid - doesn't change the geometry it simple certifies that a
geometry is of a particular projection - basically
I am because I say I am
Transform - moves a geometry from one projection to another
I am not , but please make me so. Of course the please make me so will fail
if you don't know what it is to begin with
So all being said, your statement 2 is wrong and should be
update izmir_il4 set the_geom=Transform(the_geom,32635);
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of orkun
Sent: Friday, May 16, 2008 4:00 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] couldn't get the correct projected values
hello
whatever I have done, I couldn't get the correct projected values in postgis
environment.
1. # lon/lat to utm projection
create table izmir_il4 as select
gid,il_kod,iladi,transform(the_geom,32635) as the_geom from il_izmir3;
2.
update izmir_il4 set the_geom=setsrid(the_geom,32635);
3.
select extent(the_geom) from izmir_il4;
extent
BOX(26.2226982116699 37.8668251037598,28.4587249755859 39.3925666809082)
but these are not utm values. They are still in lon/lat values
I checked extent values with proj values. I got correct values:
echo "26.2226982116699 37.8668251037598" | proj +proj=utm +zone=35
+ellps=WGS84 +datum=WGS84
431631.23 4191323.84
orkun at orkun-desktop:/usr/local/izmir/veri/izmir3$ echo "28.4587249755859
39.3925666809082" | proj +proj=utm +zone=35 +ellps=WGS84 +datum=WGS84
625615.27 4361356.53
how can get values generated from "proj" in postgis environment ?
what am I doing wrong ?
here is the srid values of 32635 :
32635 | +proj=utm +zone=35 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
regards
Ahmet Temiz
Jeo. Müh.
Afet Isleri Gen. Md.lügü
Deprem Ar. D.
Ahmet Temiz
Geo. Eng.
General Dir. of
Disaster Affairs
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
