[postgis-users] Does ST_AsText truncate or round
Andy Anderson
aanderson at amherst.edu
Fri May 16 13:36:09 PDT 2008
f & g are output formatting codes, f is the normal double-precision
format, while g produces scientific notation (mmmE+xx) if the number
is < 0.0001. The 8 and 15 represent the number of significant digits
to print (for g).
-- Andy
On May 16, 2008, at 3:33 PM, Obe, Regina wrote:
> First I can't remember what g means. I remember seeing fs and gs
> somewhere before so I can only assume that f means round and g means
> truncate?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, May 16, 2008 10:39 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Does ST_AsText truncate or round
> It all falls down into this function:
> write_double(double val){
> ensure(32);
> if (lwgi)
> sprintf(out_pos,"%.8g",val);
> else
> sprintf(out_pos,"%.15g",val);
> to_end();
> On Fri, May 16, 2008 at 3:23 AM, Paragon Corporation <lr at pcorp.us>
> wrote:
>> Slight clarification about what I am trying to solve.
>> After edits I am coming back with lines that used to be intersecting
> no
>> longer intersecting and that still have the same AsText
> representation.
>> My hope is to reduce the precision of my geometry in the database so
> the
>> edits don't break the topology of my lines by doing something like
> this
>> Update sometable
>> SET the_geom = ST_SetSRID(ST_AsText(the_geom), mysrid)
>> But I fear that if AsText is doing a rounding rather than a
> truncation, that
>> I run the risk of breaking things that used to intersect. I am more
>> concerned about under intersecting than over intersecting.
>> Although I
>> probably haven't thought this out enough so maybe it's a non-issue.
>> Thanks,
>> Regina
> Paragon
>> Corporation
>> Sent: Friday, May 16, 2008 12:01 AM
>> To: 'PostGIS Users Discussion'
>> Subject: [postgis-users] Does ST_AsText truncate or round
>> Hopefully this is a simple question. I know that ST_AsText returns a
>> geometry that is not necessarily as prescise as what is actually
> stored in
>> the geometry field. I have an editor that relies on WKT
> representation.
>> Anyrate just wanted to know if the ST_AsText does a rounding of the
> points
>> or it does a truncation of the points. Also would be nice to know if
> I
>> could control the precision of this since I will need to truncate my
> actual
>> geometry accordingly so that both are in agreement.
>> Thanks,
>> Regina
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
