[postgis-users] 3D index in postgis
a1001800
a1001800 at gmail.com
Sat May 17 21:56:34 PDT 2008
Please see the sql SELECT id, AsText(map_geom) AS geom FROM maps where ST_Equals(map_geom,GeomFromText('POINT(3 3 1)', -1));
And it matches point(3 3 1), point(3 3 2), point(3 3 3) ...
The geo field and index is below:
SELECT AddGeometryColumn( 'maps', 'map_geom', -1, 'GEOMETRY', 3);
CREATE INDEX geomk ON maps USING GIST (map_geom);
So it looks like that the index is only working in 2D
How can I build a index on the 3rd coordinate?
Thanks
Frank
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080518/b83be060/attachment.html>
