[postgis-users] I'm missing something
Bob Pawley rjpawley at shaw.ca
Tue May 20 15:05:07 PDT 2008
I took the example below and ran it and again returned the 'unknown
geometry' error.
Look like I'll need to look at the installation.
Bob
----- Original Message -----
From: "Kevin Neufeld" <kneufeld at refractions.net>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 2:42 PM
Subject: Re: [postgis-users] I'm missing something
> No, I get the same thing with WKB.
> create table tmp (geom geometry);
> insert into tmp values
> ('0105000000010000000102000000020000000000000000004740000000000020414000000000000054400000000000204140'::geometry);
> ('0105000000010000000102000000020000000000000000005440000000000020414000000000000054400000000000004E40'::geometry);
> ('01050000000100000001020000000200000000000000000047400000000000004E4000000000000047400000000000204140'::geometry);
> select astext(st_union(geom)) from tmp;
>                                  astext
>  MULTILINESTRING((46 60,46 34.25),(80 34.25,80 60),(46 34.25,80 34.25))
> (1 row)
> As Regina asked, what version of PostGIS are u using?
> select postgis_full_version();
> Bob Pawley wrote:
>> I've been attempting these operations using WKB not text.
>> Perhaps, that's the problem.
>> Bob
>> ----- Original Message ----- From: "Kevin Neufeld"
>> Sent: Tuesday, May 20, 2008 2:07 PM
>>> I don't receive an error when merging your geometries together.
>>> insert into tmp values ('MULTILINESTRING((46 34.25,80
>>> 34.25))'::geometry);
>>> insert into tmp values ('MULTILINESTRING((80 34.25,80 60))'::geometry);
>>> insert into tmp values ('MULTILINESTRING((46 60,46 34.25))'::geometry);
>>>                                  astext
>>> (1 row)
>>> -- Kevin
>>> Bob Pawley wrote:
>>>> I've attached an sql dump of the table tank_lin.
>>>> Hope this helps.
>>>> Bob
>>>> ----- Original Message ----- From: "Paul Ramsey"
>>>> <pramsey at cleverelephant.ca>
>>>> Sent: Tuesday, May 20, 2008 1:21 PM
>>>>> Attach the shape file to a bug in the bug tracker and I will have a
>>>>> look.
>>>>> http://code.google.com/p/postgis/issues/list
>>>>> P
>>>>> On Tue, May 20, 2008 at 1:12 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
>>>>>> They are three lines that, on Quantum GIS, display as a flat U - a
>>>>>> simple
>>>>>> tank. Using either tank_lin or process_dgn tables - exactly what I
>>>>>> imported
>>>>>> using dxf2postgis.
>>>>>> 'Select as text' returns three rows each with the expression
>>>>>> "Multilinestrings" followed by brackets and coordinates.
>>>>>> 'Select St_Union' returns - unknown geometry error.
>>>>>> Are you thinking there is something wrong with the installation?
>>>>>> Bob
>>>>>> ----- Original Message ----- From: "Obe, Regina"
>>>>>> <robe.dnd at cityofboston.gov>
>>>>>> Sent: Tuesday, May 20, 2008 11:51 AM
>>>>>> Subject: RE: [postgis-users] I'm missing something
>>>>>> Are these big geometries?  What does
>>>>>> SELECT ST_AsText(the_geom)
>>>>>>   FROM tank_lin;
>>>>>> Also just to rule out its the table you are inserting into  - does
>>>>>> the
>>>>>> Union without inserting work?
>>>>>> Select   ST_Union(the_geom)
>>>>>> from tank_lin;
>>>>>> ________________________________
>>>>>> From: postgis-users-bounces at postgis.refractions.net
>>>>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>>>>> Bob
>>>>>> Pawley
>>>>>> Sent: Tuesday, May 20, 2008 2:11 PM
>>>>>> To: PostGIS Users Discussion
>>>>>> Hi Regina
>>>>>> It gives me three rows each with the expression "ST_MultiLineString"
>>>>>> with nothing else.
>>>>>> Bob
>>>>>> ----- Original Message ----- From: Obe, Regina
>>>>>> <mailto:robe.dnd at cityofboston.gov>
>>>>>> <mailto:postgis-users at postgis.refractions.net>
>>>>>> Sent: Tuesday, May 20, 2008 10:56 AM
>>>>>> Bob,
>>>>>> Strange. I don't think I have ever seen quite that error before.
>>>>>> What does
>>>>>> SELECT ST_GeometryType(the_geom)
>>>>>> FROM tank_lin;
>>>>>> give you?
>>>>>> Regina
>>>>>> From: postgis-users-bounces at postgis.refractions.net on behalf of
>>>>>> Bob Pawley
>>>>>> Sent: Tue 5/20/2008 1:07 PM
>>>>>> I tried this -
>>>>>> Insert into graphics.process_dgm(the_geom)
>>>>>> from tank_lin;
>>>>>> and got the error "Unknown geometry type: 0"
>>>>>> Bob
>>>>>> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
>>>>>> Sent: Tuesday, May 20, 2008 9:51 AM
>>>>>>> You don't want the GROUP BY. It is grouping the union op on
>>>>>> distinct
>>>>>>> geometry... ie, one per row. Remove it and you'll get what you
>>>>>> want,
>>>>>>> one output row.
>>>>>>> P
>>>>>>> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca>
>>>>>> wrote:
>>>>>>>> Hi
>>>>>>>> I am attemptijng to use the ST_Union function to collapse
>>>>>> three rows from
>>>>>>>> a
>>>>>>>> table called tank_lin into one row in table called
>>>>>> process_dgm.
>>>>>>>> Here's what I used -
>>>>>>>> from tank_lin
>>>>>>>> Group by tank_lin.the_geom;
>>>>>>>> The result is three rows inserted into process_dgm, each row
>>>>>> appearing to
>>>>>>>> be
>>>>>>>> simple copies of each of the original rows.
>>>>>>>> I also attempted group by another column but received error
>>>>>> 'unknown
>>>>>>>> geometry'.
>>>>>>>> I also tried STR_LineMerge with similar results.
>>>>>>>> What am I not considering?
>>>>>>>> Bob
>>>>>>>> _______________________________________________
>>>>>>>> postgis-users mailing list
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>> The substance of this message, including any
>>>>>> attachments, may be confidential, legally privileged and/or exempt
>>>>>> from
>>>>>> disclosure pursuant to Massachusetts law. It is intended solely for
>>>>>> the
>>>>>> addressee. If you received this in error, please contact the sender
>>>>>> and
>>>>>> delete the material from any computer.
>>>>>> Help make the earth a greener place. If at all possible
>>>>>> resist printing this email and join us in saving paper.
>>>>>> The substance of this message, including any attachments, may be
>>>>>> confidential, legally privileged and/or exempt from disclosure
>>>>>> solely for the addressee. If you received this in error, please
>>>>>> contact the sender and delete the material from any computer.
