[postgis-users] I'm missing something
Obe, Regina robe.dnd at cityofboston.gov
Wed May 21 00:38:46 PDT 2008
Bob,
You make it sound like you have to perform major surgery.
Which OS are you running?
 It should be a fairly straightforward upgrade
1)  Replacing the lib/liblwgeom.dll or .so file with the good one  and share\contrib\postgis\lwpostgis_upgrade.sql and share\contrib\lwpostgis.sql files with the new ones
2) then running the share\contrib\postgislwpostgis_upgrade.sql against your database
If you are installing with an install package (most do step 1 for you) so you just need to do step 2.
The important thing is (YOU DO NOT NEED TO RELOAD YOUR DB) for this simple change and should take about 5 - 10 minutes.  This change doesn't affect how data is stored, adds a few functions, and fixes the external c functions of existing ones)
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Bob Pawley
Sent: Tue 5/20/2008 6:29 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] I'm missing something
I was hoping not to have to do that - but.
Thanks everyone for your help.
Bob
----- Original Message -----
From: "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 3:23 PM
> Bob Pawley wrote:
>> This is the version recently downloaded with Postgresql 8.3.
>> POSTGIS="1.3.2" GEOS="3.0.0rc4-CAPI-1.3.3"PROJ='Rel.4.5.0, 22 Oct 2006"
>> USE
>> STATS
> Hi Bob,
> Sounds like you are suffering from one of the many PostgreSQL 8.3 bugs in
> 1.3.2. Upgrade to 1.3.3 and the problem should go away.
> HTH,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk <http://www.siriusit.co.uk/>
> T: +44 870 608 0063
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080521/b714ed9d/attachment.html>
