[postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
Rob Tester
robtester at gmail.com
Fri May 23 10:52:46 PDT 2008
My understanding of the storage schemas available is that the data can be
stored in the native PostGIS format, I said WKB because we are all familiar
with that representation of the data from PostGIS. It can also (by default)
be stored as "SDE native in Postgres".
I am also working closely with another commercial company that is rebuilding
their existing mapping engine and they keep everything in WKB internally,
and yes they have support for PostGIS (no SDE required), but their product
is still in alpha testing.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Martin
Davis
Sent: Friday, May 23, 2008 10:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
Can you clarify your statement "The geometries can be in WKB or SDE".
If the SDE is truly using PostGIS then surely the geometry has to be
stored in the PostGIS internal format (which is neither WKB or SDE). Or
are you talking about the "SDE-native-in-PostgreSQL" implementation,
which I believe was also going to be provided as a product (the great
thing about SDE is that there's so many to choose from.... And lots
more bug reports to enjoying reading... 8^)
Rob Tester wrote:
> Okay, I have the current 9.3 rc1 with the SDE and PostGIS. I also have
> talked with some of the developers at ESRI and can tell you the following.
> Yes the support for PostGIS does exist. The geometries can be in WKB or
SDE
> (we keep ours in WKB). According to the developers of SDE for PostGIS
there
> isn't a large difference in the type anyway. But you can't use both at the
> same time, so you have to pick your poison.
> I have also patched ZigGIS so that it works with just the ArcGIS Engine
> which is what we use to develop our applications.
> Rob.
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
