[postgis-users] srid
Andy Anderson
aanderson at amherst.edu
Mon May 26 19:46:14 PDT 2008
It seems like you might be better off using ST_Translate() to
translate an object's location than to use ST_Transform() to change
the underlying spatial reference. If you want to draw objects on the
same canvas, you need to have them in the same spatial reference;
that's the purpose of ST_Transform(). If you can start with everything
in the same spatial reference and merely translate them around, I
would think it would involve a lot less processing.
-- Andy
On May 26, 2008, at 9:33 PM, Bob Pawley wrote:
> That is what I am attempting.
> I know of Visio. My thought of using Postgis is to, if possible, use
> the functions that Postgis provides. In the very long range I was
> also considering the 3D aspect of Postgis.
> Your suggestion of using "boxes", presumably to provide reference
> points is my backup method, if ST_Transform isn't applicable.
> I would still like to consider ST_Transform as it appears to be a
> more flexible approach.
> Bob
> ----- Original Message ----- From: "Chris Hermansen" <chris.hermansen at timberline.ca
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Monday, May 26, 2008 6:05 PM
> Subject: Re: [postgis-users] srid
>> Or, in another direction... Bob, if your "geometrical data" is
>> meant to
>> be something like a "data flow diagram" or a "process diagram", you
>> can
>> surely do that with PostGIS.
>> Doubtless you must be aware of tools like Visio (in Windoze) or Dia
>> (in
>> Linux or Windoze) that are made for drawing diagrams like "data
>> flow",
>> but nevertheless you've decided to put your data into PostGIS
>> instead.
>> Then you probably want to make some "boxes" in your process diagram
>> appear above, below, to the right of, or to the left of, other boxes.
>> To do that, you would need to define some kind of partial order on
>> the
>> boxes (this box is to the right of that box, etc). This sounds
>> like a
>> topological sort to me.
>> Presumably you could turn that topological ordering into some set of
>> offsets that could be applied to compute coordinates of each box.
>> is that where you're trying to end up?
>> Andy Anderson wrote:
>>> On May 26, 2008, at 3:06 PM, Bob Pawley wrote:
>>>> However, I attempting to interpret functions made for geographic
>>>> data
>>>> to use with geometric data.
>>>> I have PostgreSQL tables which represent engineering processes.
>>>> I want to display that data in a graphical form - hopefully using
>>>> Postgis - - - if I can translate the functions (or the Postgis
>>>> concept) into a form that I can use.
>>> Hmmm... if all you want to do is display X-Y data, I would suggest
>>> using geographic coordinates, e.g. SRID = 4326 (WGS84 datum), which
>>> most programs will display by default with X and Y rectilinear.
>>> However, you earlier said you wanted to use ST_Transform(geometry,
>>> integer), which implies you want to switch between different
>>> geographies.
>>> So it sounds like you need to pick a particular projection for
>>> your work.
>>> Is your geography spherical or spheroidal? If so, you might want to
>>> define your own datum. If not, you'll need to use a projection to a
>>> flat surface. What's more important, that it be conformal
>>> (equiangular) or equal area or that it preserve distance in one
>>> direction?
>>> -- Andy
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Regards,
>> Chris Hermansen mailto:chris.hermansen at timberline.ca
>> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
>> Timberline Natural Resource Group · http://www.timberline.ca
>> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
