[postgis-users] Attributes update
    Obe, Regina
    robe.dnd at cityofboston.gov
    Fri May 30 04:54:09 PDT 2008
Markus,
Rule of thumb for relation operations - I think you always read it  A
function_name B
So A within B -> Within(A,B)
I think that holds true for all the spatial relation functions in
PostGIS.
Lucas - Markus gave you the correlated sub query approach.  You can also
do it without a subquery.  Which one is faster depends on how big your
data sets are I think.  The non-correlated I think generally works
better (especially for large data sets) (make sure to have indexes on
both geom fields).
I think the correlated sub query always forces a nested loop join.
Below is a non-sub query way of doing it.  For the new versions of
PostGIS you can also replace the && Within with just ST_Within.
UPDATE land_use SET type = parcels.landuse
FROM parcels
WHERE
ST_Within(centroid(parcels.the_geom),land_use.the_geom);
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Markus Schaber
Sent: Friday, May 30, 2008 7:26 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Attributes update
Hi, Lucas,
"Lucas Mueller" <lucas.mueller at gmail.com> wrote:
> I have two polygon layers (let's say Parcels and Land_use). I would
like to
> assign the attribute Land_use.type to the Parcels.landuse column by a
query
> that assigns a certain land use type to a parcel if the centroid of
the
> parcel is within a certain land use polygon. I hope to be clear
enough...
> Any idea on how to proceed?
Try something like:
update land_use set type=(select parcels.landuse FROM parcels where
land_use.the_geom && parcels.the_geom AND
within(centroid(parcels.the_geom),land_use.the_geom));
Btw, I tend to mix up the argument order of within and contains, so
please double-check.
Regards,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
