[postgis-users] Spatial Operators
Paragon Corporation
lr at pcorp.us
Sat May 31 05:35:51 PDT 2008
Marcus,
It would help if you provided the sql statement you were trying to run that
gave you a problem.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Marcus
C. England
Sent: Friday, May 30, 2008 7:45 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Spatial Operators
Hi all,
Well, moving to PostGIS as a spatial data format has helped a lot with
trying to learn SQL, but I still have problems with the SQL syntax for
spatial operators. Here is what I want to do:
Layers:
(1) basin_grading: polygons representing the impact area of a proposed
basin, plus 100' and 200' buffers. Whether the polygon represents grading or
a buffer is stated in attribute column "land_use"
(2) new_vegetation: polygons representing vegetation communities. The
community names are in attribute column "veg_".
The problem:
I would like to use sql to generate a table of vegetation types and the
acreages impacted by each land use in "basin_grading". I would assume you
would use "ST_Intersection", but I have tried to alter quite a few examples
of its use that I found on-line and I always get an error about my syntax.
Tips, pointers, etc are greatly appreciated.
-Marcus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
