[postgis-users] WKT polygon and interior ring orientation
Sufficool, Stanley
ssufficool at rov.sbcounty.gov
Mon Nov 3 08:32:04 PST 2008
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Mark Cave-Ayland
> Sent: Monday, November 03, 2008 5:21 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] WKT polygon and interior ring orientation
> Kevin Neufeld wrote:
> > If you look at the OGC spec v.1.1.0 and the current v1.2.0, Part 2,
> > the
> > only reference to orientation is in a footnote, "Polygon
> rotation is not
> > defined by this specification; actual polygon rotation may be in a
> > clockwise or counter-clockwise direction."
> > Prior versions don't even mention orientation.
> > http://www.opengeospatial.org/standards/sfs
> > It's my understanding that polygon orientation doesn't
> really matter
> > and
> > even varies from one database vendor to another. Martin
> Davis may be
> > able to answer the whys better, but since the specs didn't
> specify at
> > the time, I believe JTS/GEOS chose to follow the somewhat
> more accepted
> > orientation and follow the Right-Hand-Rule - that is, the
> orientation of
> > the rings are such that the thing they are bounding is to
> the right. In
> > particular, an exterior ring is clockwise and interior
> rings are counter
> > clockwise. PostGIS even has a forceRHR for polygons ... but like I
> > said, I don't think it really matters.
> > -- Kevin
> I vaguely remember reading somewhere that if you are trying
> to calculate
> normals to a plane (or something similar) then you must have
> the rings
> in the same orientation. Now the interesting thing to notice is the
> MS-SQL's geometry type enforces ring orientation, so we can
> only guess
> that they need this property for some of their spherical calculations.
I assume you mean GEOGRAPHY type. The SQL 2008 GEOMETRY type does not
suport spheroid projections/calculations.
Does ring orientation matter when you are calculating point in poly?
When you calc a point in poly, do you take the sum of vertex angles from
point to poly vertex and if sum of angles is >= 360 then point is in
poly?
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts http://www.siriusit.co.uk
> T: +44 870 608 0063 _______________________________________________
> postgis-users mailing list postgis-users at postgis.refractions.net
