[postgis-users] WKT polygon and interior ring orientation
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Nov 3 08:49:10 PST 2008
Sufficool, Stanley wrote:
> I assume you mean GEOGRAPHY type. The SQL 2008 GEOMETRY type does not
> suport spheroid projections/calculations.
Yes, sorry I meant geography rather than geometry. Doh.
> Does ring orientation matter when you are calculating point in poly?
> When you calc a point in poly, do you take the sum of vertex angles from
> point to poly vertex and if sum of angles is >= 360 then point is in
> poly?
I can't see that PIP should care too much about orientation. Some
googling shows up this link though:
http://msdn.microsoft.com/en-us/library/bb964711.aspx
This implies that the restriction is related to functions that determine
whether one thing is within another. Hmmm.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
