[postgis-users] migrating from linux to windows
Willy-Bas Loos
willybas at gmail.com
Thu Nov 6 08:45:29 PST 2008
Hi Pedro,
Ok, i know dblink. I could do some replace(..) on the library file
locations, but that seems pretty hairy..
Maybe it would be easyer to use create_undef.pl and then just load a dump of
the undeffed db into a freshly created database with postgis, i just hope
that my geometry data will not be lost.
Otherwise i could try to modify the resulting SQL to not to drop the
geometry type for example.
I'll give it a shot and report back.
WHY IS THIS NOT IN THE MANUAL??
I guess that could have something to do with finances etc.. :(
cheers,
WBL
On Thu, Nov 6, 2008 at 5:04 PM, Pedro Doria Meunier
<pdoria at netmadeira.com>wrote:
> Hi Willy
> If everything else fails you might turn to db_link ...
> Willy-Bas Loos wrote:
>> Hi,
>> I want to migrate a postgis database from postgis 1.1.6 on debian to 1.3.3
>> on windows. (i know, i like linux better too)
>> what's the correct way to go about that?
>> Will the perl script postgis_restore.pl work?
>> I'm trying it out, but i am encountering some problems that might not be
>> related.
>> So would it work in theory or is there a better way?
>> thx
>> WBL
>> "Patriotism is the conviction that your country is superior to all others
>> because you were born in it." -- George Bernard Shaw
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081106/08451408/attachment.html>
