[postgis-users] Coordinates transform
Lonelu Lukas
lonelu.lukas at gmail.com
Tue Nov 11 06:06:44 PST 2008
Hi All,
I have a list of longitude / latitude records in TM65 projection which
needs to be transformed into Google Map standard (UTM). Is Postgis proper
tool for that kind of transformations ? I mean .. can I import the data and
then use sql function to transform the data ? If yes could you point me
somewhere I could start ?
Regards,
Luk
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081111/dcc4878a/attachment.html>
