[postgis-users] shp2pgsql question
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Wed Nov 12 06:11:00 PST 2008
Dana,
You can also run it in the manner that you are, i.e., exporting the
output to a file. I am curious, what does the script output look like
if you run it without dumping it to a file, i.e.:
c:/shp2pgsql -s 26912 -p c:/Jordyn Jordyn
Whatever error message it dumps should be useful.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Nandorov
Sent: Friday, November 07, 2008 3:26 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] shp2pgsql question
Dana:
inside your postgis bin directory you have to run:
shp2pgsql [options] [shape file] [schema][table] | psql [database]
for example:
shp2pgsql C:\shp\myshape.shp public.test_shp | psql mydatabase
maybe it will be more helpfull:
http://postgis.refractions.net/documentation/manual-1.3/ch04.html#id2868
133
Hope it helps,
Regards
Dana Lee wrote:
> Hi,
> I'm new to PostGIS and am having troubles running shp2pgsql. When I
run
> the
> command below nothing happens, there is not Jordyn.sql file in my C
drive.
> I've copied the shp2pgsql.exe and shapefile to my C drive and changed
my
> current directory to my C drive, then tried running the command with
and
> without the c:/ but nothing ever happens. I'm not sure what I'm doing
> wrong.
> Any help or advice would be greatly appreciated. Thanks.
> c:/shp2pgsql -s 26912 -p c:/Jordyn Jordyn > c:/Jordyn.sql
> Dana
> postgis-users mailing list
View this message in context:
http://www.nabble.com/shp2pgsql-question-tp20387316p20388273.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
