[postgis-users] Convex Hull with a certain "offset"
Stefano Bonnin stefano.bonnin at comai.to
Fri Nov 14 02:28:45 PST 2008
Hi all,
I'm be able to create a convex hull of a certain number of points, but
I'd like to find a convex hull "a little bit bigger". Is there a way to
add a certain offset to the polygon
obtained from the convex hull query (like ST_expand for bounding boxes)
My query is:
select ST_ConvexHull(env) as poly From (SELECT ST_MakeLine(the_geom) as
env from my_spatial_table Where gid  IN ( ... )) as foo
In other words I want to create a query like:
select ST_ConvexHull(env,50) as poly ....
where 50 is a value that increments the polygon dimensions in all
directions.
Thanks in advance.
Stefano Bonnin
Comai Torino Srl
www.comai.to
