[postgis-users] Convex Hull with a certain "offset"
Alex Mayrhofer axelm-postgis at nona.net
Fri Nov 14 03:33:46 PST 2008
Stefano Bonnin wrote:
> I'd like to find a convex hull "a little bit bigger". Is there a way to
> add a certain offset to the polygon
> obtained from the convex hull query (like ST_expand for bounding boxes)
Applying ST_Buffer() to the output of your query should do exactly what
you are looking for. See a practical application of the buffer function
in the map at http://timatio.com/traces/19069-sll-brandstadl
Alex
http://timatio.com/
