[postgis-users] Convex Hull with a certain "offset"
Stefano Bonnin stefano.bonnin at comai.to
Fri Nov 14 04:11:36 PST 2008
Alex Mayrhofer ha scritto:
> Stefano Bonnin wrote:
>> I'd like to find a convex hull "a little bit bigger". Is there a way
>> to add a certain offset to the polygon
>> obtained from the convex hull query (like ST_expand for bounding boxes)
> Applying ST_Buffer() to the output of your query should do exactly
> what you are looking for. See a practical application of the buffer
> function in the map at http://timatio.com/traces/19069-sll-brandstadl
> Alex
> http://timatio.com/
> postgis-users mailing list
Thanks a lot, exaclty what I want!
stefano
