[postgis-users] Problem in migrating shapefile to postgis
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Fri Nov 14 07:26:35 PST 2008
You rule Regina.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe, Regina
Sent: Friday, November 14, 2008 10:21 AM
To: PostGIS Users Discussion; nguyenquangvinh20052005 at yahoo.com
Subject: RE: [postgis-users] Problem in migrating shapefile to postgis
I think I may have figured out the problem. I tried the file. It doesn't load into a UTF-8 encoded database. You need to use the -W switch if you have a UTF-8 encoded database.
Try
shp2pgsql -g the_geom -s 32648 -I -W "latin1" LopGiaoThong LopGiaoThong | psql -U postgres -d postgis
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of vinh nguyenquang
Sent: Wednesday, November 12, 2008 12:36 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problem in migrating shapefile to postgis
Hi, everyone
Can you help me load LopGiaoThong.shp vao trong postgis? I have problem
with SRID or something else i don't know.
I do it in this way: shp2pgsql -i -D -s LopGiaoThong.shp LopGiaoThong >
LopGiaoThong.sql
psql -d postgis -U postgres -f LopGiaoThong.sql
I do not know the parameter -s: what value it is to load LopGiaoThong.shp
Can you show mw how to find the value of -s parameter (SRID) of my data or
how to load my data to postgis?
Thank you very much!
Re: I still can not load LopGiaoThong.shp to postgis. Even though, I tried with -s parameter: 32648, 4326, 3405. I really can not find the correct SRID's value of my data. I really appreciated if anyone can help me do it.
Thanks!
_____
Nước nào thường cho nhiều học bổng du học? Khám phá tại Yahoo! Hỏi & Đáp <http://sg.rd.yahoo.com/mail/vn/footer/def/*http:/vn.answers.yahoo.com>
_____
The substance of this message, including any attachments, may be confidential, legally privileged and/or exempt from disclosure pursuant to Massachusetts law. It is intended solely for the addressee. If you received this in error, please contact the sender and delete the material from any computer.
_____
Help make the earth a greener place. If at all possible resist printing this email and join us in saving paper.
_____
_____
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081114/4787270c/attachment.html>
