[postgis-users] Ellipses and WGS84
Bruce Rindahl rindahl at lrcwe.com
Tue Nov 18 10:18:42 PST 2008
Your parameter r is in map units.  For your example r = 1 or a 1 degree
circle.  The center section should be :
buffer(GeomFromText('Point(0.0 0.0)', 4326), 1)
Now you have a circle (polygon actually) with a radius of 1 unit
(degrees) centered at point 0,0.
Next you need to scale the circle to create an ellipse.  You do this
with the scale factors a and b.  These parameters are dimensionless
(ratios).
The query becomes scale(buffer(GeomFromText('Point(0.0 0.0)', 4326),
1),a,b)  where a is the meters per degree of longitude and b is the
meters per degree of latitude at your final point cx,cy.  This gives you
an ellipse at point(0 0) with the correct shape.
Next is a rotation function to create an arbitrary ellipse.  You do not
need this so eliminate it.
Finally translate the ellipse to your desired location - cx cy.
translate(scale(buffer(GeomFromText('Point(0.0 0.0)', 4326), 1),a,b),cx,cy)
Read it from the inside out. Make a unit circle (buffer) then scale it
differently in x and y (scale (...),a,b) then move it to the location
you want (translate(...),cx,cy)
Bruce
 David W Talmage - CONTRACTOR wrote:
> Bruce Rindahl wrote:
>> The example creates an ellipse directly in a projected coordinate
>> space.  What you need is the difference between latitude and
>> longitude of 1 meter at the location you want.  Your code should be:
>> translate(rotate(scale(buffer(GeomFromText('Point(0.0 0.0)', 4326),
>> r),a,b),alpha),cx,cy)
>> Where r is the radius in decimal degrees of 1 meter at the equator, b
>> =1 (the 1 meter distance does not change in the N/S direction), alpha
>> is 0 since you will not rotate the ellipse, and cx and cy are you
>> final lat/long locations.  The a parameter is tricky.  You need to
>> know how much larger 1 degree of longitude is than 1 degree of
>> latitude is at cx,cy.  You might try:
> Thank you for helping me!
> I should have worded the problem differently.  I need to make an ellipse
> with a and b greater than 1.  Following the code, I start with a 1m
> circle, then scale it up to a-meters by b-meters.
> So the r, a, and b are all in degrees?  Then I have to figure out how
> many meters per degree at latitude cy and divide r, a, and b by that
> number, right?
> If that's right, then something strange is going on.  I'm creating the
> ellipse that way and my SELECT asks for all things whose bounding box
> intersects that of the ellipse.  PostGIS is returning far fewer things
> that I expect.  Here's my SELECT:
> SELECT rf.name FROM raster_entry re, raster_file rf WHERE
> re.raster_data_set_id = rf.raster_data_set_id AND rf.type = 'main' AND
> (re.ground_geom &&
> I'm doing this in Java with a PreparedStatement.  The '?' correspond
> to r, a, b, alpha, cx, and cy, respectively.
>>> Would someone please explain the units in this snippet modeled after
>>> the exampled offered in
>>> http://postgis.refractions.net/pipermail/postgis-users/2007-March/014971.html
>>> What are the units of r, a, and b?  I think they are radians.
>>> My intention is to create a 1-meter radius circle at the Equator,
>>> morph  it into an ellipse and then move the ellipse to an area of
>>> interest on the globe to select the things that are in that area.
>>> All of my things are stored with coordinates in WGS84.
>>> I know the values of a and b in meters.  I have a function that
>>> computes the number of meters per degree on an ellipsoid at any
>>> latitude, so I can convert a and b to radians.
>>> I'm pretty sure that cx and cy are the longitude and latitude,
>>> respectively, in degrees of the center of the ellipse.
>>> alpha is in radians.
>>> I've looked all over for an answer to this question and either I
>>> can't find it or don't understand what I've found. :-(
> postgis-users mailing list
