[postgis-users] Ellipses and WGS84
David W Talmage - CONTRACTOR talmage at cmf.nrl.navy.mil
Thu Nov 20 07:07:34 PST 2008
Bruce Rindahl wrote:
> Your parameter r is in map units.  For your example r = 1 or a 1 degree
> circle.  The center section should be :
> buffer(GeomFromText('Point(0.0 0.0)', 4326), 1)
> Now you have a circle (polygon actually) with a radius of 1 unit
> (degrees) centered at point 0,0.
> Next you need to scale the circle to create an ellipse.  You do this
> with the scale factors a and b.  These parameters are dimensionless
> (ratios).
Ratios!  I get it now.  Thanks!  My SELECT now works as I expected it to.
