[postgis-users] PostGIS 1.3.4 RC3 released
Chris Hermansen chris.hermansen at timberline.ca
Wed Nov 19 09:52:07 PST 2008
WRT Ubuntu and GEOS versions, the current version (Intrepid, 8.10) has
finally made the move from 2.2.4 that is in the Hardy 8.04 LTS release
and stands at 3.0.0-5.
I recall many people begging as far back as the GEOS 3 RCs to have them
moved into Ubuntu, maybe that was in 7.x series?   Anyway.
It seems that the 8.04 LTS release will be supported until April 2011,
so I guess in principle that means there will be people hoping for
support on GEOS 2.2 until that time.  Yuck...
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> Mark,
>> My general opinion about this.  No its not worth the effort unless it
>> takes you 5 minutes and won't break anything and doesn't require further
>> maintenance :).
>> I figure most people upgrading are probably going to upgrade GEOS.   I
>> mean you expect all functions to be available in your install and if
>> they happen to be running a geos that old, I question whether they would
>> be running the new GCC.
>> Also its annoying to have to say things like hmm by the way you can't
>> use ST_SimplifyPreserveTopology because you don't have GEOS 3.0+.  Too
>> much minutia to remember.
> For people who are reasonably happy compiling code, it's probably not
> so much of an issue. The annoying part is that some LTS distros
> (Ubuntu, I'm looking at you) are still shipping GEOS 2.2 series, even
> though 3.0 had been out nearly a year before the distro shipped. So
> for these people we still need to maintain 2.2 series support IMO.
>> Does the old gcc work fine with old 2....?  If so then scrap fixing it
>> for new installs -- you want to stick with old technology stick with old
>> technology across the board period.  If it doesn't then hmm - I would
>> say lets just say to use 1.3.4 you need to have Geos 3.0.3 or above
>> installed.
> I wouldn't mind this so much, except for the fact that 1.3.4 contains
> critical memory leak fixes/crash fixes that people really need to have
> in production :(  However, for 1.4 I have no objection to making GEOS
> 3.0 a minimum requirement - this would at least enable us to get rid
> those final compilation warnings. Feel free to put forward a proposal
> on -devel :)
> ATB,
> Mark.
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
