[postgis-users] Google Mercator and PostGIS under Ubuntu
Frens
fj.rumph at gmail.com
Wed Nov 19 10:46:32 PST 2008
I am using PostGIS for a project quite succesfully until recently I tried
moving applications from my Windows based development environment to a
Ubuntu based test / demo environment. The postgis versions etc. are exactly
the same: "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS". The database used on the Ubuntu machine is a restore of a
backup from the windows machine. (the database is an open street map db for
NL).
How ever I get some weird behaviour from the translate function on the
Ubuntu machine. For instance if I execute the following query:
SELECT ST_AsEWKT(
ST_transform(
ST_transform(
GeomFromText(
'POINT(5.167485 52.271499)',
4326
900913
4326
on my Windows machine I get: "SRID=4326;POINT(5.16748499999999 52.271499)".
Which is what I expect. However, when I execute the exact same query on my
Ubuntu machine (with the same postgis / postgres / etc versions) I get:
"SRID=4326;POINT(8.10187206703149e-07 8.19541802859524e-06)". The only qlue
I have is that I get this warning: WARNING: transform: -38 (failed to load
NAD27-83 correction file).
So far googling didn't pay off... Anyone got some ideas?
P.S. 900913 is the SRID I use for the Google projection system, with the
following data in spatial_ref_sys:
srtext =
"PROJCS["Google Mercator",GEOGCS["WGS 84",DATUM["World Geodetic System
1984",SPHEROID["WGS
84",6378137,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Mercator_2SP"],PARAMETER["standard_parallel_1",0],PARAMETER["central_meridian",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1],EXTENSION["PROJ4","+proj=merc
+a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
+nadgrids=@null +wktext +no_defs"]]"
proj4text =
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +wktext +no_defs"
View this message in context: http://www.nabble.com/Google-Mercator-and-PostGIS-under-Ubuntu-tp20585295p20585295.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
